Is anyone making a few dollars with a Horizontal Mill?
  • Is anyone making a few dollars with a Horizontal Mill?
    Thanks to some interesting pointers from a few members I was able to reasonably price and complete the last job. There is more work available, much of which seems to currently done on a Bridgeport. I may be able to price the job well, and be quick about it by straddle milling the parts in my Horizontal Mill ( Pedersen 12 by 50). But I wonder, does anyone else use a horizontal nowadays or if not why not? Secondly does anyone run a digital readout on a horizontal, and is it really useful? regards David Powell.
    Yes, on XY&Z
    & Yes,
    very useful for setting up,
    invaluable when doing a closed ended slot,
    also when using it as a horizontal boring machine
    more reliable than eyes & memory
    plus you don't have to worry about any backlash
    john
    John
    I used to be indecisive. Now I'm not so sure , but I'm not a complete idiot - some bits are still missing
      Friend of mine produces Picatinny scope base stock, uses his horizontal to cross groove the bases for the scope rings.
      David
      David Kaiser
      ― Robert A. Heinlein
        Yes to the horizontal, bo to the DRO.
        I just put a 3/16" keyway in 3ft of 5/8ths. Thing is, you know the cutter is going to be as good when you finish as when you start. A vertical cutter would get knackered halfway down, and you'd want to take a few passes at it anyway.
        I'm getting better at knowing the limits of my mill, and when the horizontal will do it, I find it's almost always worth the back-breaking effort of unloading the vertical head.
        I recently got hold of an old slab mill, so there's excitement round the corner !
        Richard - SW London, UK, EU.
          A heavy horizontal will remove metal MUCH faster than a Bridgeport. I used to get a particular job every year that I made a lot of money per hour doing with my Harrison horizontal mill. It consisted of milling 4 "V" shaped grooves each way on 8" squares of brass sheet,so they looked like tic-tac-toe games. This enabled the square sheets to be accurately folded up into cubes. Part of awards that were given every year.
          I made the first batch 1 groove at a time,but then made a 4 cutter milling cutter which not only cut 4 grooves at once,but automatically insured accurate spacing without measuring,shifting the table by precise amounts,etc..
            I haven't done any in awhile,but I used to run 1-1/2 and 2" OD shafts for a local company.They were 40" long and needed 8" of keyway in each end.
            50 pieces each and each one would take 15 minutes per end.I think I have done nearly 500 of them on the same two cutters and they are still sharp.
            Would have been a nightmare on a Bridgeport.
              My local Caterpillar dealer before I left NY had a large horizontal with about a 70" table in their fabrication shop. They used it for everything from line boring to hogging metal, and made quite a bit of money with it daily. Now that I think about it, that may have been their only mill.
