4 Jaw Chucks RULE!!!!!!
  • 4 Jaw Chucks RULE!!!!!!
    ok i got my 4 jaw chuck and mounting plate in from busy bee today for my lathe only cost me 150.00 with tax and shippping..
    good deal for being on sale, any how i set her all up slaped in a peice of aluim and in less then 10 min had it dialed in at way less then half a thou of total run out not bad for doing it by eye , slaped on the indicator to verfi my thoughts and man its so sweet i dont know how i went this long with out one, now i can add to my skills and turn stuff alot more percision then ever ,,
    ok so iam a kid at christmas
    Yup. Plus, they tend to be larger than stock 3-jaws.
    Since my mini-lathe, I put a 4-jaw on and rarely use anything else. I like being able to flip a part and machine somewhere else, and ensure the runout is nonexistent.
    Spend time on it and--yes, I have done this a few times--you can dial it in until your indicator shows .0000.
      Couldn't agree more. I used a battered old three jaw for years. Now I have four jaws on both lathes, and the three jaw chucks haven't been off the shelf in two months.
      I find it much more fulfilling to dial in on a four jaw than to mess with shimming in a three jaw.
      I say to myself I'll work on my three jaw chucks, but I really see no reason why I'd want to use them again.
      The only boring thing is winding one or more jaws right out to swap ends. I'm thinking of dedicating a drill/driver to that.
      I prefer a nice thin lightweight chuck to those heavy beasts though. I have two of the former, but I need a third.
      Richard - SW London, UK, EU.
        With a bit of practice a part can very quickly be made to run true in a four jaw chuck. Other very nice benefits are that a four jaw can grip a part MUCH more firmly than a three jaw, allowing heavier cuts, smaller gripping areas, and longer unsupported work pieces extending from the chuck.
          Just remember that that will only happen with a ground surface finish, a good dial indicator will show irregularities in the order of 0.01 mm at the surface of a turned piece
            I hope everybody is talking about an "independent 4-jaw chuck". If you have a "universal 4-jaw chuck" - your parts would better be turned! If not - that is where a 3-jaw comes into play.
              I bought a 4 jaw independent chuck
                I like my 4-jaw. Sadly it won't grab anything smaller than 3/8" in dia.
                  So go get a cheapo mini-lathe chuck, grab your work with that and then grab the little chuck with the big 4 jaw and get it dialed. Or, get a Er collet chuck and grab that with the 4 jaw....once it's centered, the Collets are pretty repeatable.
                    Yeah no doubt about it...4-jaw chucks rule!
                    Not only do you have repeatability, but it also opens up a whole new world of material that can be turned.
                    With a bit of practice it won't take any longer than a three jaw to dial in either, especially when one considers the degree of repeatability that is inherent with the 4-jaw.
                    I believe everyone should only have a 4-jaw for the first 2 years of lathe use, after that, unless it's repetitious work, you'll seldom look at a 3-jaw again.
                      we get ripped off so bad in canada with our busybeetools and kbctools ...
                        and gas, housing, groceries, cars, clothes, etc., etc. ......
                          3 jaw chuck.. Uhh, thats the one for holding hex stock securely right?
                          Congrats though on learning the way! Soon you'll be able to dial things in to thou within a min.
                            I have both a four jaw indy and 4J self centering. I have no three jaw at at all. The 4J SC is pretty accurate, but can't compare to dialing in an indy chuck. I'm not even sure what a four jaw SC is really good for as opposed to a three jaw; it just came with my lathe.
                            BTW, the 4J SC chuck is a big honkin piece of steel, I like it cause I swear it has a flywheel effect on my underpowered South Bend 9".
                              A truly good 3-jaw chuck also has value. I have a 10" Pratt Burnerd Super Precision that holds anything in its range within .0005". I have a 12" Pratt Burnerd 4-jaw independent chuck, but I've only had it on the machine once that I can recall.
                              I've used 4-jaw independent chucks for many years in the places I worked. I know what they can do, and I know what I can do with them. For 95% of what I need to do on the lathe, the good 3-jaw chuck or the collet closer do just fine.
