Reading the JBweld thread led me to thinking about a job I have on at the moment. 6-cyl diesel, one-piece head. It blew head gasket 4 years ago. I had the head skimmed, cleaned up the top of the block but it's not good. Fitted head with new joint + some high-temp jointing (Loctite product IIRC, can't remember which). Told the owner not to expect miracles, he was planning to sell the boat while the going was good.
4 years down the line, he still has it & it's blown the gasket again between two cylinders. Block really needs refacing, but that's quite a big engine-out job, not practical at present and may cost more than the boat is worth.
So.....is there any magic metal compound which could be used on the block face to build it up, which has a good chance of extending the life?
I have Belzona 1111 to hand, but I wouldn't expect any of these epoxy-based compounds to last very long where they're in contact with the combustion space, even if it's only a very thin 'edge' which is in contact initially. Maybe I'm being too pessimistic?
Thanks
Tim
Thanks
Tim
