Originally posted by Arthur.Marks
I have a Buck which is substantially the same as the Bison, except that the setscrews are at 0,90,180,270.
I do not believe you have correctly described the system.....
The chuck body has 4 setscrews in it for the Bison and for the Buck. The backplate has a "spigot" which the screws engage, and the backplate mates with the selected spindle nose type.
I really don't see how else they could do it, except to make it somewhat skinnier.....
I made a backplate for my Buck, doesn't add much if any length to the stickout.
I don't see where Bison "added" any extra at ALL to the chuck in the OPs pictures.... the seam you see is needed for the collet pinion.
In the case of the six jaw, I again fail to see the added portion...... unless you suppose the spigot could extend further into the chuck body........ probably it could, a small amount, but.......
