Another good thing you can do with an analogue meter is quick basic capacitor tests on large-ish capacitors. Ohms range, probes across the cap. Hopefully, the needle jumps up and drifts down. Or goes nowhere, or goes up and stays up. With practice, you can even get a pretty good idea what the drift rate means. (Kinda like the guy they used as a voltmeter by measuring how high he jumped when they connected him to the circuit, or putting your thumb over the spark plug hole to measure the compression...
Digital meters update what? Once per second typically? An analog meter does not give an instantaneous reading either, but it is limited by the reaction time of the coil & movement, which is much faster than that.
This one looks an awful lot like the Lafayette I build from a kit in the early 60's as a barely teenager.
