I am trying to fix the run out in my drill press and I lost like 6 of the damn balls...
My 1st thought was to replace the bearings in general.. but I cant.. I have weird measurements...
Its an axial bearing, no cage to hold the balls...
Anyways the size's.. OD is the same for both of the plates.... .9965 but the ID is different for the top and the bottom.. One is .4990 and the other is .5335
Its not a wear issue as there is a larger bearing lower in the assemble with the same thing....This drill press has 4 bearings..2 for the down thrust (axial) and 2 for side to side (thrust) although 1 of the thrust bears is very high up for the transmission of power area....
Should I just replace the balls?? If so what kind? The balls measured .1210
The shaft which runs through the whole assembly ran very straight in my lathe.. yet wobbles in the press.. not sure why yet...
