Ideas or thoughts????
I have two Bosch Bulldog roto hammers. One is a 11212VSR, the other a 11210VSR.
Both have bad trigger speed controls. The trigger switch is listed as no longer available from Bosch. And, a local independent repair guy said nobody else supplies these type parts.
On the 11212 model the switch has two wires in, two out, with the reverse switch a separate unit. So, if I put a toggle switch in place of the trigger I may lose the variable speed, but will have full speed only.
The 11210 has the reverse built in. A bit more complicated.
So what to do? I hate to throw the tools out. Maybe jury rig a trigger switch form some other tool?
I don't care if the repair is kind of clunky. These are for my own use.
