Automatic Chain saw sharpener
  • Automatic Chain saw sharpener
    I ordered a professional chain sharpener that is made in Sweden. It is called a Grindomatic V12. You can find it easy on YouTube.
    You just put the chain on, make a few adjustments and press go. Everything works by itself.
    I was really skeptical but this machine really does a good job. My chains have never cut better. It is especially good for my .404 chains. It takes about five minutes per chain including setup.
    It is a 12 volt machine with a converter for running it off house current. Or you can take it with you on the tractor and run it off the battery.
    I did this in response to the thread on here about sharpening chains.
    Just a bit of trivia for all you woodsman.
    Is it really 1800 Euro?! Seems a lot.
      It might be, 12000 SEK + VAT(25%) in 2004 was the only price I found with a quick search. 1 EUR is about 9 SEK today, 2004 it as about 10 SEK.
        I like fancy gadgets as much as the next guy, but for that price I could buy a LOT of chainsaw files and chains. Any chance of getting a video up?
          Just go to Youtube and search on Grindomatic V12. If I have time tomorrow I will make a video.
            When should we expect a new set of pictures of pretty girls on top of your Grindomatic?
            WI/IL border, USA
              The name does lend itself to some colorful interpretation!!!
                Exactly!
                WI/IL border, USA
                  Just watched a utube vid of it in action, chains wont last long with the amount it was grinding off each tip!!
                  Peter
                    ptjw7uk: I would assume its set wrong in some of the youtube vids, Also if its got proper scales on the controls, You could reset it to only grind a few thou off whatever the last grind it did, Since the chain would presumabley be the exact form it grinds after the first sharpening.
                      Peter
                      It can be set to grind off any amount you like, the video was simply showing how it can take off 4mm without overheating the teeth.
                        this machine lives at the acceptable end of the market.(in terms of function).. except the price makes it a non starter for small businesses.
