I have been reading about the virtues of a VFD vs. a phase converter. It is my understanding that the VFD does everything that the phase converter will do and does it better.
A phase converter puts out about 80% of the power sent to it (as I understand it)and therefore requires a unit with about 30% more HP than the motor youi are using to drive the equipment. How does a VFD compare to this?
I hope I will be needing a phase converter in about 2 weeks as I am supposed to go and look at a South Bend 15x60 in a few days and should it be all that it is supposed to be I shall bring it home. Then I will have to find a way to drive the thing from my single phase current. Should I opt for a VFD or go with a phase converter? How do the 2 compare as far as price is concerned? How would I go about taking advantage of everything a VFD would do?
Thanks again guys.
Thanks again guys.
