Big old stepper motors @ 9.95 each......
  • Big old stepper motors @ 9.95 each......
    Slo-Syn(r) Stepper tell a friend about this item so they can check it out
    This clean 24 VDC takeout stepping motor from Superior Electric is 4-1/8" x 2" dia, with (24) 15-degree steps per revolution. It is (5) wire, draws just under 2 amps and has 65 oz/in torque. The bottom has a removable 2-1/4" square mounting plate and a 1" x 1/4" dia shaft ending in a 7/16" x 1" dia pulley. On the top is an identical shaft topped by a 1-7/8" encoder wheel, and a bracket that holds a 6-pin-edge zoom encoder. The motor's (5) leads terminate in a 6-pin molex-type connector.
    34055 SYN STEP MOTOR $9.95 / EACH add to cart
    SYN STEP MOTOR
    http://www.sciplus.com/category.cfm?...8&category=174
    5 leads, usually you just use 4 for a gecko or a larken drive..
    Hope this helps someone.
