The Grizzly or Jet "Bridgeport Mill" clones seem to be a reasonable alternative to "the real thing" at a much lower price. On the smaller floor mills (8x36) the head only tilts left/right and swivels 90 degrees. None of the smaller "clones" have a tilt adjustment forward and aft. Is this a problem when you are "tramming" the head to get square cuts on all four sides of a block of material around the X and Y axis?
It seems like you could only assure square cuts left and right of the spindle and not in front of, or in back of, the spindle.
What's the story on spindle adjustments with these "clone" Bridgeports?
I'm sure it shows, but I am new to machine work.
