Boring & Facing Head Help
  • Boring & Facing Head Help
    I have a 2 Feed Boring/Facing Automatic Head that MSC sells as MSC #: 00695346.
    The trouble is I have no manual/instructions and MSC is unable to provide one. From much research I have learned that this is the same as the Gamet and Enco 222-1100 Boring/Facing Heads. A search here revealed that a few people have had the same issue; not having an instruction manual. Other posters have been able to provide them with a copy of one. My hope is that I will be as fortunate.
    Thanks in advance for any help with this issue.
    Please disregard the above request, I was able to obtain one outside the site. If anyone else ever needs it I have it saved in PDF and will gladly send it out to you upon request.
    do you have specific questions on its use, or just want a manual? If its import you might not want the manual anyway!
    KEJR
      pm me with your email address and will email back with a pdf manual of the Enco-Gamet boring facing head.
        It appears Steve has already found his manual.
        He edited his post at 1:03 PM to say so.
