This is still huge compared to a watchmaker's re-pivoting lathe. Powered by a string and rubber band, it will let you drill a .006 hole in the end of a watch wheel arbor!
After a few years of use as a clamp, try using it for measuring - you'll find the frame thing has stretched nicely, so that all the bits you machined too much off now have spare metal on them and they fit again!
Beats running the lathe in reverse to put metal back on.
