Cheap winch/power transmission ideas
  • Cheap winch/power transmission ideas
    I'd like to build a lift table to raise lawn mowers and snowthrowers to a good working height. I've sketched out a few ideas, using a die lifting table as a design, but mine will be significantly lighter duty (like 200lbs max capacity). I just want something that can do the awkward lifting that is tough to do alone.
    However, I need a power source to raise the table. die-lifting tables ive seen have airbags, which are pricey, so are hydraulic or pneumatic actuators. I thought of getting an electric winch from Harbor Freight, but they're all 12 volt, so i'd need a transformer.
    Another idea is a gear reduced, reversible motor with a length of acme threaded rod, but i dont know where to find a cheap motor like that.
    I was wondering if anyone had an idea for cheap power transmission in an application like this
    How about a auto floor jack or bottle jack. Both under $25.00
      Bottle jack is a good idea mcskipper, but its overkill and it would take alot of pumping to raise the table.
      I take a lawnmower on/off a table about 15 or more times a day, to test start it and so on. I was trying to think of a rapid, relatively low power source that could push the table up or down in a few seconds
        Why not start with a Harbor Frieght motorcycle lift?
          jack
          Sir,
          How about some sort of scissors/platform arrangment with an air cylinder and some sort of quarter-turn valve(s) for letting the air in and out??? It should be fast and easy to do.
          Regards,
          JCC
            What about a hand winch something like this one: http://www.northerntool.com/shop/too...5596_200395596
              Check HF or some other cheap outlet for hydraulic log splitter and rip the hydraulics from that. In here I can get one for 200 EUR (incl. 23 % VAT, so without tax that is like 200 USD). This way you get electric motor, the hydraulic pump, hydraulic valve and a long stroke piston (1000 mm seems to be common) with 5-6 tons of force.
                For only 200 lbs I'd be thinking low tech; along the lines of a block and tackle system. From floor to waist high we're talking 3 or 4 seconds, and moving less than 5 ft of rope.
                Assuming you have a suitable overhead attachment point of course.
                  You could incorporate the B&T into the lift along with a crank to take up the rope. The typical hunter's B&T is usually a 500# cap so that may just do the trick.
                    Years ago, I built an elevator for a friend's beach house so he could get upstairs in his wheelchair without assistance. I used 4" PVC pipe with a plastic piston inside to lift the platform nine feet from the ground to the raised deck.
                    The power was supplied by the city water system by opening a valve to fill the cylinder. Another valve drained the cylinder when he wanted to come down. The waste water was piped to a sprinkler in the yard.
                    I used a counterweight on a cable to balance the weight of the platform, so only the live load (about 200 pounds) was moved by the cylinder. The platform was cantilevered off a frame with boat trailer rollers that ran up and down a stout wooden beam.
                      Why not some threaded rod and a half inch variable speed power drill?
                      I bet you already own the drill.
                        Enco has Acme threaded rod (3' length) and nuts for reasonable cost.
                        -bill
                          If you can find an old bumper car jack that will give you plenty of lift, a very old VW jack had a long threaded rod and a little right angle gearbox at the top for the handle.
                            Something like this?
                              Possibly a simple ramp up one side and down off the other.??
                              Dunno, but just a thought.
