Octagon inside a circle
  • Octagon inside a circle
    What's the formula for determining the exact distance across the flats of an octagon inside a circle of a given diameter, in this case it is an odd size of 1.033.
    Sqrt(trig)
      From google W=.9239D, where W = width of the octagon and D = the circle diameter. If I understand what you are looking for correctly,
      1.033 * 0.9239 = .9543887.
      Edit - this is for an octagon with the points (vertices) touching the inside of the circle.
        Hmmmmm...... here we go...
        http://buster2058.netfirms.com/octag...ayout_calc.htm
            You know that the base angle of each section facing the flats is 360 divided by 8 or 45 degrees. Dividing that to get a right triangle for trig gives 22.50 degrees. Then you know the length of the hypotenuse is 1/2 the circle diameter so half the distance across the flats is (1.033/2) * cos 22.5, and the across flats distance is twice that or .95436.
            EDIT: Which I see does not agree with the book. Hmmm.
              Thanks guys that one sure had me confounded big time! I not only got my problem solved but I leaned something new, thanks again!
                Isn't it sin(22.5).
                Phil
                  Originally posted by philbur
                  Isn't it sin(22.5).
                  Phil
                  Some People Have, Curly Black Hair, Through Persistent Brushing
                  sine = p/h
                  cosine = b/h
                  tangent = p/b
                  One thing I was missing was not multiplying the book constant by 1.033 so I think I'm out of the woods now.
                    The distance across the flats is just diameter x cos 22.5 which is .92387. The book said .9239.
                    I don't understand what your 1.033 is Tgtool.
                    Philbur, I always work everything out from cos. In this case, sin will give you the length of the flats.
                    Richard - SW London, UK, EU.
                      sine = p/h
                      cosine = b/h
                      tangent = p/b.
                      ?????? p h b ??????
                      don't look/sound like any parts of a triangle I've ever seen .
                      I guess h may be hypotenues, but p and b for adjacent and opposite?????????
                      ...lew...
                        We referenced Chief soh cah toa to remember this.
                        Sine= Opposite/Hypotenuse
                        Cosine= Adjacent/Hypotenuse
                        Tangent= Opposite/Adjacent
                        Guaranteed not to rust, bust, collect dust, bend, chip, crack or peel
                          Originally posted by Lew Hartswick
                          ?????? p h b ??????
                          ...lew...
                          Right, oPposite, Base, and Hypotenuse
                          That's the size of the OP's circle. Factor times actual circle size. I knew you knew that.
                            You could download a free copy of Draftsight 2D CAD. Very handy for these and other type problems of this sort.
                              What is "Chief?"
                              Lynn (Huntsville, AL)
