At what rockwell hardness is it not possible to machine with HHS cutters?
Say I want to make a precision thread and want to heat treat the rod and then cut the threads. This eliminating the distortion of heat treating. What rockwell should I aim for. I don't want to harden the rod so much that I can't cut it with HSS cutters.
I see that MSC sells acme threaded rod. Am I safe to assume that I can machine it?
Thanks
Thanks
