Rockwell Univise vs. Unihead: What's the diff?????
  • Rockwell Univise vs. Unihead: What's the diff?????
    Can anyone who has these 2 explain their differences?? Pix would be great!!
    Thanks!
    Harry
    I don't do drugs.
    At my age, I can get the same effect if I stand up too quick!
    They are two different animals.
    Unihead;
    http://vintagemachinery.org/pubs/detail.aspx?id=1888
    Univise, this is a chicom clone being sold by Tools for Cheap. It differs somewhat from the Rockwell, but is functionally the same;
    http://www.tools4cheap.net/proddetail.php?prod=univise
    Jim H.
      The Unihead holds a collet that in turn holds the tool to be ground (much like a 5c Spindex). They are Brown & Sharpe #9 taper if I recall correctly. The Univise holds the tool directly in its jaws and can be used to sharpen faceted tools such square or rectangular planer, shaper and lathe bits.
        The one I have is B&S #11.
          Yeah, I think I have one kicking around here somewhere too. Whatever the taper is, it's not anything currently common so they're kind of a PITA to tool up.
          Hmmm, now I'm wondering if my KO LEE head might also be the same taper, but it has a sleeve to adapt to a 5C collet taper. That's why I use the KO LEE and not the Unihead.
            must be a hybrid...
            Thanks for the replies!
            Evidently the RW versions used the same base casting (except for the name). I just looked at one that has "Unihead" cast into the base and the business end has jaws similar to the offshore knock-off.
            Harry
            I don't do drugs.
              A detail no one has mentioned. Neither are meant for use on a milling machine. Both are grinding fixture and lack the rigidity for milling.
                Yes,I recall the univise literature from the 60's,for grinding tools. I have an old,but unused univise now.
