Circle coordinate calculator: New updated more flexible version
  • Circle coordinate calculator: New updated more flexible version
    A comment on the previous thread started me thinking about how to improve the utility. It now is much more flexible in specifying the arc length and position. It also now will calculate the length of a flat (chord) for any number of flats (max 360) within any arc up to a full circle.
    It is only 41kb
    http://ixian.ca/server/circlecalcv11.exe
    Thanks Evan.
    Dwayne
    "When it comes to paradigms ... shifts happen" - Alain Rossman
      A worthy improvement, but with a bug in the angle readout.
      Allan Ostling
      Phoenix, Arizona
        What bug?
          3131.0 line 7
          Ernie (VE7ERN)
            Using exactly what settings? It is probably a formatting error. Just curious, does a value of 313.1 make sense?
              Evan, look at the screen shot you posted
                The angle values should be
                231.00
                244.83
                258.66
                272.50
                286.33
                300.17
                314.00
                327.83
                341.67
                355.50
                009.33
                023.17
                037.00
                The ones indented printed out erroneously.
                Allan Ostling
                Phoenix, Arizona
                  Download it again and try it. I found a small roundoff error for certain values that produce formatting problems.
                  Without knowing the settings you used the results aren't meaningful.
                  Unfortunately, computers do not always produce accurate results even for rational numbers. This because the math is done in binary and then converted to decimal. For instance, In binary 0.001 is an irrational number.
                    The corrected values shown above are for the settings in your OP. I cannot download it unless you make a Mac version.
                    Allan Ostling
                    Phoenix, Arizona
                      I noticed that and fixed it. Don't you have a PC emulator Allan?
                        I hesitate to open up that can of worms.
                        Allan Ostling
                        Phoenix, Arizona
                          How sad. I actually fired up wine* to look at Evan's program. First time I've used it in 5 years.
                          Nice program, though my DRO does that for me. And my phone too.
                          I should learn the math instead.
                          Dan
                          * Wine is a windows emulator that runs on a Linux system
                            Do the graphics work correctly under WINE?
                              Don't be scared!
                              I run a wide variety of CAD, CAM and other Windows apps on my Mac -- all run perfectly and reliably. VMWare Fusion baby!
                              PM
