Aluminum grades
  • Aluminum grades
    I was wondering where I could find out more about different aluminum alloys & terminology?
    As an example,
    Wrought material, 2024 aluminum, temper T4.
    Forging, 6151 aluminum, temper T6 .
    I would like to understand exactly how these two aluminums differ from each other and what each is suitable for. This is just an example as I know there are other grades of aluminum that would like to understand as well.
    Thanks for your help.
    There's a little info here,
    http://scholar.google.com/scholar?q=...=1&oi=scholart
    Gene
      "Grade" is not the term you are looking for. Scrap is sold by "grade". The terms you have are Alloy and heat treatment or "condition". Search for "aluminum alloys" and "applications" and that should keep you busy for a while.
        http://www.matweb.com/index.aspx This link ought to get you enough information to give you a migrane.
        More info than most folks will need in a lifetime.....
          Try this link, more information than you probably want.
          http://books.google.com/books?id=Lsk...page&q&f=false
            For some good thumbnail summaries, go to www.mcmaster.com and type "about aluminum" into the Find box.
            But matweb, recommended by JohnnyD, will tell you EVERYTHING....
              Thank you that was very helpful.
