Nuts, Striped a M6 thread today in aluminum while puting my bike back togethor. Kinda critical too since it sorta holds the motor on.
Thankfuly this is in a large chunk of aluminum with lots of space around the thread... I... hope. I should really double check since there is a clutch bore close by, but I should at least be able to get 1/2" of M8 thread in, and if I drill into the clutch, its OK as long as I don't drill so deep as to damage it, its just grease filled.
Its about 1" deep, blind, though the bolt into it only engaged by about 1/2", theres another 1/4" of good thread at least before it tapers. Not really enough to be secure however with just a longer bolt, but im thinking a longer bolt should be used after repair, and for the other mounting hole?
I could in theory tap it out to be M8. I do have some high grade M8 threaded rod I could make a bolt outta. Space for the M8 bolt head + wrench might need some grinding but I think it should be doable.
Id rather use an insert however. Its the aluminum that failed, torn right out, down to about 80% of the root. Bolt thread looks fine. Happened while torqueing it to the same level I allways do, So I kinda suspect some of the thread had allready been damaged by stresses. (Going over bumps, chain falling off (Fixed), etc)
So, down to my questions. What are peoples feelings on verious inserts, Iv heard some people don't like the spring coil like inserts, but I don't recall anyone really saying why.
And would I be much better off taping it for M8 if I can?
