W7 or XP ?
  • W7 or XP ?
    Not wanting to hijack Evans exploding software thread but I have recently had an upgrade on my machine from a corrupt copy of XP , corrupted thru time, onto W7.
    Now it's running OK but I'm not that impressed with W7 and I have given it a month, some program have to run under XP mode and two have to run in a XP virtual window supplied my Microsoft.
    Add to this I run as a user, not admin so I'm forever having to enter admin password to do anything.
    So the question is, "Is it worth going back to XP ?"
    Can I have answers from people who have trod this path and not just people who have a preference between the two ?
    to relieve the need for password use an admin acc
    if UAC is on turn it off (should also eliminate need for PW, but without specifics it is hard to say)
    for compatibility... you just have to live with it or update your other SW. My experience to date is that if it runs in an xp window on 7 it was probably running in a compatibility mode on xp anyway.
    definately not worth going back to XP
    if you used an upgrade rather than a clean install you are always going to have some issues, almost always legacy stuff that the upgrade left in place to accomodate things that might need it.
      John
      I have w7 on a new lap top (no choice) and Dolphin-partmaster locks up now and then and...stick with xp . Use it in the shop and NEVER had a problem....
      eddie
      please visit my webpage:
      http://motorworks88.webs.com/
        Personally, I like W7 and have no complaints with it. I also like XP. At some point though, XP will be obsolete. I guess only you can decide when you want to upgrade your other software to work seamlessly with W7, or whatever comes after W7. Even with your current software, running in XP mode doesn't seem particularly burdensome. The requirement to use the XP virtual machine could get annoying. Your tolerance for annoyance will determine your decision.
        In my case, I found that all my applications, with a couple of minor exceptions, run under W7 with no problem. The only things I couldn't get to run were a couple of extremely ancient 16-bit apps, and I didn't particularly need them.
          MS is supposedly "supporting" it until 2014, IIRC.
          "Obsolete" is as obsolete does...... Microsoft could, legally, pull your licence for XP on the date that they stop "supporting" it, although they have no history of doing this (yet). I believe the user agreement allows that.
          In practice, what happens is that nothing new runs on it, and you end up being unable to use nerw versions of IE, FireFox, Flash, Acrobat reader, etc, and so it becomes more-or-less useless for the web.
          I know of people who still use DOS, or Win 95, for certain things because they have to use a program that requires it. There are programs that will *not* run in a "DOS compatibility window", one being the "Alpha 4" database program (although in that case there are upgrades to Win versions, with varying compatibility).
          Some computers may not work well with W7, which is, at least, a nuch better program than the "large icon, primary colors, Nursery school" thing that was "Vista".
          Bottom line is that on 1/1/2015, XP probably won't cease to operate. If stuff you use that doesn't upgrade needs XP, use it.
            What exactly doesnt' run? I have win 7 32 bit and I've been able to run everything I've tried, but I don't tend to run old software on my machine at home.
            I need to get into it for work, because we run some older software for programming machines, but so far its just been kind of lurking as something "we need to do soon". I don't relish the idea of running a bunch of programs in XP mode (or using vmware) but then again it does offer some advantages such as having a complete operating environment that you can "seal" up using the feature of not saving to the virtual disk. The advantage of this is that if you ever got a virus or made a mistake logged in as administrator to the virtual machine you could just restart your virtual machine and it would be like reverting to a clean drive image. I've not used XP mode, but my understanding is that it is just virtual PC made somewhat easier/transparent to use.
            I personally would not set your normal user as administrator in Win7. Microsoft has finally come to the point where Unix has been for years and it promises to be more secure. If you are typing in the administrator password for alot of programs I would re-examine if you need to use those programs. The exception is the annoying Java runtime and Adobe flash updates that seem to have plagued us all. Look at it like this, if someone wants to change core files in your system, you should *want* to specify extra security password just to make sure some rogue program/virus is not trying to install itself as a service, etc.
            KEJR
              Likewise -- I was surprised by that comment. Are you trying to run old DOS programs, or are these programs with legacy device drivers?
              The big change (for the better) between XP and Vista/Win 7 is that the latter moved all the device drivers into user space. The vast majority of blue screens/system crashes are due to crappy third party drivers. So moving the device drivers into user space (User-Mode Driver Framework) means that crappy device drivers can crash and not affect the kernel.
              The problem with UMDF is that, like a 64-bit port, it requires a complete re-write, so many legacy device drivers haven't, and won't, be ported.
                I have W7 on my MacBook Pro under bootcamp for running Solidworks. I have had issues with it like altering write privileges on file forcing me to complete re- install of SW instead of an upgrade for SP4.0
                Other than strange things like that Windoze is Windoze.
                I read that as of this week windows update will not work unless you are running SP3.0
                Next MS is coming out with their newest OS Windows 666.
                  One other thing you might run into is Win7 wants to see signed drivers. You will probably have to tell it to allow unsigned drivers. Just dont install 64bit version, it requires signed drivers. There is a hack to allow you to run unsigned drivers, I have had to use it to run some older stuff.
                    I run Win7 on 4 of my machines, three 32 bit and one 64 bit, and XP on another for the handful of old programs I thought I'd need. "Thought", because most I mostly didn't. It forced me to search for subsitute programs that would run under Win 7, and hey, they were a heck of a lot better then what I'd been hanging onto for a few decades. The XP machine mostly gathers dust.
                    I'd ditch XP in heartbeat on that last machine, but my Nikon film scanner software will never get drivers for WIN7 - Nikon's solution - buy a $500 third party software solution.
                    I was also confused for a while about needed to run certain programs "as administrator", but that's an easy fix (set up a separate "admin user" or if you want to take the risk, run as admin). Most of my programs have had updates and no longer need to run as admin, except for some updates.
                    One thing that Win7 loves... memory... Load it up...
                      I would strongly advise not to do that!
                      Almost all unsigned drivers circumvent the User-Mode Driver Framework that guarantees that drivers don't crash the kernel.
                      To get a driver signed is free and dirt simple -- it's not like you're getting WHQL certification.
                      http://msdn.microsoft.com/en-us/wind...dware/gg487317
                        Yeah, but some times you have old unsupported hardware with ancient drivers and the company is not going to submit them for signing. Then you are stuck.
                          Running win7 64bit and most impressed.
                          Downsides so far: My old steering wheel does not have drivers anymore, they droped support for it same release as they added win7 support, bastards.
                          Basicly, Win7 64bit is great if your buying new everything else to go with your system, or leaving your older stuff attached to other PC's.
                            I switched over to Win7 last year. But, I was a little leary of the new program and architecture, so, I partitioned my hard drive and set up a dual boot, so I could keep both Win7 and XP on the same computer. A few weeks ago, I re-partitioned the hard drive again, and uninstalled XP.
                            I guess I'm in the group that likes Win7.
                            As far as running programs, I've discovered that if I let Win7 "have" the program in question, it magically seems to make adjustments and pretty soon, whatever the program was, that wouldn't run in Win7, all of a sudden does.
                            Point of example: My CAD program, "TurboCad Professional" V12 would not run on Win7 when I first put Win7 on my computer. I wrote to IMSI (the makers of TurboCad) and asked them if they had drivers or a work-around so I could run it on Win7. They bluntly replied that I would have to upgrade to the latest version of TurboCad ($400), because they didn't intend to offer anything to make TurboCad run on a Win7 computer...except the new, Win7 compatible version of TurboCad. I also wrote to Microsof and asked the same question. No, they didn't have anything that would allow TurboCad to work in Win7 either....Tough luck, either buy the $400 upgrade, or keep XP, just for the CAD program.
                            Then one day, I needed to do a CAD rendering for a part I was making. I inadvertantly clicked on the TurboCad icon, and there it was! I opened the program, and went through as much as I could...everything worked perfecty, even the 3-D rendering software, and the movie functions of TurboCad...except they were way faster.
                            The same thing happened with my Graphics program. One day, I couldn't open it, the next day it was all there and functioning perfectly...Is my computer haunted?
                            Please excuse me, I have to go into my CAD program and design a "double-barreled, bolt action, revolver" for one of the guys.
                            No good deed goes unpunished.
                              There's a lot of self-healing features in Win7. I wouldn't doubt that it's capable of making adjustments for drivers. I've recently started looking into how Superfetch and Prefetch work, or not, with SSDs. When Windows 7 "becomes aware" of the speed of a particular SSD, it starts changing various parameters on it's own. And I don't just mean stopping Defrag. Besides that, Win7 will lock, or restrict use of, an internal drive used for backup. It's not necessary to use an external drive. Many, many things are going on in Windows 7. I run Win7 Pro x64 and like it. Windows 8 will be out in 2012. If MS will support XP to 2014, look for an abrupt stop of XP support across the board--Hardware and software.
