I intend to build a propane fired furnace burner. My question is this: Aside from thread fitting issues, will any gas regulator work with any gas? (I'm aware of the cautions to be observed w/Oxygen reg's). More Specifically, can I use an Acetylene welding regulator if I can adapt the fittings.
Thnx for your inputs.
