push button switch
  • push button switch
    I am looking for a motor control switch, a two button, start/stop 220acv 20-30amp. I am coming up empty searching the net. Will someone give me a couple of manufactures or links?
    Usually, two button switches are One stop button wired hot one side, other side to start and hold contacts on a electric starter or relay (to maintain the contactor closed untill the stop is pressed) . Other side start button directly to coil of magnetic starter or relay to pull it in.
    it takes 3 wires. A starter or motor relay takes more.
    What are you wanting to turn on and off? a motor? you need a manual starter for that, it has the buttons made into the contactor. Push the start and the contacts close via a rod or mechanical connection, stop and they open.
    Ebay is the most cost easiest to get. I use them all the time. Sorry I don't have any manual starters laying around here.
    I'll help if I can, tell us a little more about what you want to do, and we'll help you get there.
    David
      I would try Grainger for motor start/stop switches.
      www.grainger.com
      You might also try McMaster-Carr
      www.mcmaster.com
      or Graybar - sorry I don't know the URL.
      [This message has been edited by Paul Alciatore (edited 01-23-2004).]
      Make it fit.
        Burden Surplus Center might have something - look under the "electrical" tab:
        http://www.surpluscenter.com/
        hth,
        Ian
        All of the gear, no idea...
          Any company that sells industrial controls such as Westburne or Westco/Westinghouse sells the industrial 1-1/4" Oiltight panel switches and indicators.
            thanks guys
            J
