Power cords on Makita tools, disintegrating..
  • Power cords on Makita tools, disintegrating..
    Anybody else having the problem of the power cords on Makita potable power tools disintegrating?
    Three tools, abrasive cutoff saw, circular saw and router, all 5 to 12 years old. The outer rubber on these cords is cracking and breaking off. The tools themselves are functioning like new.
    This is not uncommon on power cords, I've had others do this, but these are the only Makita tools I've owned and they're all doing it. I have a number of Porter Cable tools that get equivalent usage and are far older with no cord problems at all.
    I don't expect cords to last forever, but I have to think this situation is somehow unique to Makita.
    All that chinese rubber is crap... All recent car tires purchased are pretty crappy.. dry rot. We got some six months old on the Honda Fit, were cheap mind you.. but... rotting off the rims now with plenty of tread.
    Buy a chinese inflatable tire from HF, get a lot of use from your air compressor.
    Mikey says they are made outa screen wire..
    Excuse me, I farted.
      Gee and in another thread I'm getting crap for not liking Chinese machine tools. Glad to find someone else who is not enamored with Chinese goods.
        I had a heavy extension cord I made up for one of my welders. The cable was #8 / 3 SOW SOO or something like that. It was made by Royal Electric. Within about 5 years I noticed the outer jacket was cracking much like yours. The cable was never exposed to weather or sun light. I came to the conclusion that the manufacturer had the crap made in china. I have some rubber extension cords that are 40 + years old and look and feel like new. I brought the cable back to the local HD and they replaced it. I see this with a lot of power tools and other things........ stiff vynal cords that are a real pain to have on any power tool or appliance.
        JL......................
          Have had to replace the cord on my Dewalt 4 1/2" grinder a few times.
          I always thought it was because I usualy set it down on the welding table and the UV light from the arc was rotting it out.
          Ted
            Ted
            Mine too - but I'm positive it is not from UV light
              I have had cords go bad on a lot of power tools.Dewalt and Milwaukee.The Porter Cable stuff seems to be holding up. I got a roll of 3M fusion splice tape that I use to wrap the cracked areas.Some I have replaced with SO cord.
              I came to same conclusion you guys,lousy rubber
                Same problem here with Makita tools and some other brands to a lesser extent . The Makita stuff is easily the worst, it just totally crumbles.
                  I think it's UV or ozone related, but it may be water and gasoline starting the problem. Not all cords are classified as water/gas/oil resistent, some are just water.
                  I replace cords on all types of tools for my contractor friends so often they never get a chance to rot, but my Makita cutoff saw that has has been outside for 15 years needs replacing. I replaced my Makita drill cord maybe twice in 25 years, but it gets a lot of grief.
                  I doubt Makita has a "special cord" made just for them.
                  I use SOxxx cord that's water oil and gas resistent (If forget the exact designation).
                    I had a similar problem that turned out to be resulting from storing the tools in a compartment next to where PVC cleaner and glue were stored. The evaporating solvents were migrating next door and degrading the power cords.
                    Byron Boucher
                    Burnet, TX
                      One solution to the power tool cord problem I've found is to look for OLD burned out tools. Usually these are free or almost free. Salvage the cords for replacement in newer tools.
                      New replacement cords are a small fortune so that method is out.
                        Doesn't your local hardware store sell SOxxx cord by the foot?
                        I always put on on nylon Hubble/Leviton etc plugs anyhow - they can be run over many times
                          Alcohol in todays' gasoline can't help either.
                            The life of power cords also seems to be related to the climate . Many of my dad's tools and machines ( all made in the USA) had power cords that were disintegrating . He lived in South Florida. In fact, plastics and rubber items in general seemed to disintegrate in that climate, including most of the plastic interior parts in his cars.
                              Have not had any issues with power cords, but I have had problems with Snap-On screwdriver handles self destructing. Just sitting in the drawer they would secrete something oily overnight and be sitting in a puddle the next day. Clean them off, wipe up the mess and set them back in the drawer. Next day same thing.
                              Over time they would finally dry out and start cracking and flaking, turning white and powdery. (Standard black handles.) The Snap-On dealer replaced a couple (handles) and said they would probably just do the same thing again.
