Two questions
  • Two questions
    1. I have a set of 5C collets by 32nds, is there much point to getting all the 64th collets that would make up a full set, would they get used enough to make it worth while. If I am turning a piece of off the shelf bar then it is probably one of the major diam. like 1/4, 1/2, 3/8 etc and if it is a second operation then I would try and size the part to use one of my existing collets. Is this flawed logic.
    2. Are the dividing attachments for a H/V rotary table worth getting or are they difficult to use.
    Southwestern Ontario. Canada
    Metric collets are handy for small shaft work to fit standard metric bearings. I have 10,12,15,20,25 mm collets. I say this is more useful than 64ths.
    I don't know about your rotary table but if you plan to do gear work you'll need to divide.
      5c collets
      I think in a home shop the smaller set is enough. But I would have a 5c emergency collet or two on hand just in case there is a need for a special
      size.
      Jim
        You can get by with your set if you have several thicknesses of shim stock to fill out the gap in a misfit collet to shaft size. The shim needs to be longer than the length of the jaws in the collet. Don't force an over size shaft in a collet.
          Buy them (64's) as you need them. You can sometimes get a good deal at an auction on a box lot of collets. Or from a machinery dealer. Sometimes they become so swamped in small tooling that nearly new collets can be had for as little as $5. Often many of the 64's turn out to be new or little used. The duplicates in other sizes come in handy as spares, especially when you hae other lathes, jigs and fixtures that use 5C collets. Hex and to a lesser degree square collets are also handy to have.
            I don't think you would get much use from 1/64 series collets. I have the divider plates for my rotary table, and although I have read up on the theory of using them, and watched videos showing how to use them, I haven't used them. I think it would be quite a challenge.
              Agreed on their limited usefulness. That said, I bought an ultra-cheap set of 64th's. My standard sizes are all used Hardinge. I find the 64th's useful, but they are only so on stuff that isn't really a standard size anyway. Hence, the cheapo set. If I spring one, who cares. A better method would be the emergency collet route as mentioned above. Most of the time what I use them for, though, is hardly high-precision work
                Only you can answer that question. I have all the collets in 1/64'ths.,but some of the metal I pick up in junk yards is metric,so there are times when I need a 1/64" difference.
                  I got the entire set (64ths) and they have come in quite useful. As gwilson said, it depends on your own personal needs. It was worth the price in peace of mind to me to know I wasn't going to have to improvise when I had a job with a deadline by having to jump through hoops to accomplish what would be easy with the right size collet. Also, if you have other devices which hold 5C collets, as I do, by having the whole set you compound the value of both the collet as well as the attachments by having the whole set.
                    I bought them when I bought my RT. I used them quite a bit at first but never for any real fancy dividing, just common stuff like 5 holes in a drive hub or 6 in a flange. You really don't need the plates for the simple stuff and I never did much that was too complicated.
                    Then I installed a DRO on the mill that has a bolt circle function, I've never broke out the plates again.
                    The last couple days I've been making a power drawbar for my step pulley BP clone. I used the rt to clean up the edges of a couple round plates, left the plates attached to the rt and used the DRO to add all my holes.
                    THANX RICH
                    People say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
                      I am planning to get some 5Cs but will probably just get the 16ths. I can always order the others on a one by one basis as needed. Most projects require some order time for materials anyway so delays should be minimal.
                      I may get some metrics or square ones.
                      Make it fit.
                        The first time you struggle to get by without a 1/64th buy all the 64ths.
                        What I really think you are looking for is some moral support for buying more shiny metal tooling, whether you will ever have a real need for them is not a relevant question.
                        Phil
                          Do we really ever need a good reason for buying more tools, it's a disease.
                          My main reason is, will the money spent on these collets be worth it or would it be spent better else were. Limited funds and I'm trying to finish outfitting my shop before retirement, I won't have much "tool" money then.
                            You "NEED" both the 64'ths and a full set of metric, and the dividers to build what ever your next project is. I will swear on a stack of bibles to your wife they are required and save you a fortune.
                            Abner, will lie for cold beers.
                              I have a full set of 64's over about 1/4" up to 1-1/8". For my work, I don't really use small collets and have oddball sizes that I use all the time. I have everything by 1/16" (or is it 1/32"?) up to 1/4", but I have never used them, and seldom use anything smaller than 1/2" except for 3/8" for setup purposes.
                              So it really depends on what you do and the sizes that you work on. If your always using standard rod sizes, 1/64" is just a waste of money.
                              No matter what you do, you will always need a collet size that you don't have, and have collets you never use.
                              As far as the dividing attachments, it depends on how much you'll use them. They would probably be a challenge to use the first couple times, but if you use them every other day, it's easy to use.
