In the "How To Cut Navel Brass Thread" there was discussion of circular
saws for cutting metal.
Although aware that blades described as for non-ferrous materials are
available for use in woodworking table, circular and mitering saws,
I was unaware that purpose-built metal cutting circular saws were on
the market. The availability of such saws and remarks about the thickness
of ferrous material that people mentioned cutting caught my attention.
The first of some questions for those in the know:
Edit: Corrected blade speed to 7,450 SFM from 3,875 SFM
Originally posted by duckman
- How do the metal cutting circular saws differ from the wood versions,
aside from the blade/chip enclosures?
. - When used on ferrous material, are these tools still acting as cold saws
or have they moved into the realm of hot or friction sawing?
Milwaukee's 6370-20 has an 8" cermet-tipped blade that turns at
3,700 RPM, which translates to 7,450 SFM. Many times faster
than the recommended blade speed of up to 350 SFM for a (HSS)
vertical saw blade.
. - Are people cutting 1/2" & 3/4" in one pass.
