Chucks and the minimum diameter they can grip
  • Chucks and the minimum diameter they can grip
    My 6" 4-jaw won't grip anything smaller than 3/8" in diameter. I need a 3-jaw, so I figure to buy a smaller size.
    Is there any rule of thumb on the lower end of gripping capacity?
    Just get more pointed jaws for your chuck.
      Or, make pointy soft jaws.
      Or, get a collet chuck instead of a smaller 3-jaw. It'll have less runout than a 3-jaw if mounted carefully and you get good-quality collets.
        My Bison 8" 6 jaw will grip down to 5/16". For anything smaller I use a drill chuck mounted in a 1" solid socket.
        JL..................
          Buy a 3" chuck, and chuck it in your 4-jaw chuck.
            I used to chuck a Jacobs type chuck in the big chuck to grip real small diameters. You can still indicate the part in to get it to run true. I mean the type of Jacobs chuck you use in the drill press,or tailstock.
            Now I have another lathe for smaller work(Hardinge HLVH) that uses collets.
              Take out every other jaw in a six jaw and the jaws will almost meet.
              Jim H.
                It isn't a six jaw the OP is describing,though.
                  This is my 250mm (9.84") Pratt Burnerd Super Precision 3-jaw scroll chuck. It' seems to be able to hold down to somewhere around 4mm (.156") quite securely. And, near-zero runout no matter where it's measured.
                  It was sold to me by a former employer for $250, never had been on a machine.
                    A friend of mine sculpted out a set of soft jaw for his three jaw so it accepts 5 C collets. Works pretty good and he saves several hundred $.
                    Chucking a 3" three jaw in a larger 4 jaw works well for small sizes too. You can adjust the 4 jaw to exactly center the three jaw.
                    I suggest bolting the three jaw on a disk of 1/2 thick round stock made to fit but having a 1/4" larger OD for the 4 jaws to grip on. The disk takes the abuse of the jaws and not the smaller chuck body.
                    I have a couple dozen split bushings I've made over the years for different things including a number that have been tapped. I slip them in the three jaw for smaller work or bolts I have to grip to mod the head.
                      For really tiny stuff, I've put the small rod in pin vises and then chucked the pin vise in the lathe.
                      VitŮŽria, Brazil
                        Forrest has it......
                        That's what they make collets for
