Free to a good home(s); Southbend parts
  • Free to a good home(s); Southbend parts
    I have a few odds and ends from what I believe was a 9" SB lathe that was cannibalized to build a specialized machine. I have no need for these, so if anyone can use them, they are available for cost of shipping from 01826. Any and all will fit in flat-rate packages.
    These do not have to go as a group, if you just need one part, please ask and it's yours.
    There is:
    1) A tailstock quill, clearly well used but functional
    2)A tailstock base casting, you can see the casting number in one of the photos
    3)A gear that I believe is the one that mounts on the spindle and drives the threading geartrain.
    4) There are also a couple of small brass keys that were part of the headstock bearing assembly, that are visible in the photo of the gear.
    Some photos here:
    http://smg.photobucket.com/albums/v4...hbend%20parts/
    If you can use any of these parts, please let me know. Please do not ask for them if you plan to resell them, I can list them on ebay myself if I wanted to do that. I am hoping these can be of use to someone rebuilding a machine or two.
    Thanks for looking.
    -Al
    I'd like them. I'll PM you.
      PM me your info and they are yours.
      -Al
        For what it is worth, those look to be heavy 10 parts.
        I doubt any of them will fit a 9" lathe.
          You could be right, I never saw the original machine. Any tell-tale markers to go by?
          I do not own a SB lathe, so was just going by the recollections of someone else.
          Thanks.
            My 9" South Bend does not have a removeable gear on the spindle, it is an integral part of the spindle.
            Don Young
              sb parts
              I could use the brass keys if they are not spoken for.
              Bill
