1/2 13 Unc Flange Nut
  • 1/2 13 Unc Flange Nut
    Also called TEC-41605
    spare nuts for Bridgeport clamping kit
    any sources cheap in the UK
    all i can find is seller on ebay that want £9.80 for 6..free postage ..but for chinese things seem still high
    or j£l industrial who want £1.20 each..and would be a special order from the USA
    HMM when i don't want to pay that
    I would rather order something over 20 and get a deal.as i seem to loose them all the time .
    Yes , i can get ordinary nuts by the bucket load ...but these flange nuts are meant for the job..thicker walled ..large flange ..hardened.
    all the best.markj
    No, I can't help with a supplier. But the nut you seek is a DIN 6331 nut, maybe that will help?
    Thomas
    Problems worthy of attack prove their worth by hitting back
    - Piet Hein
      OK thanks Thomas
      all the best.markj
        You might try Travers Tool Co www.travers.com but the shipping charges will probably be prohibitive.
        Or you could make a flanged nut yourself out of whatever you have that is equivalent to 1144 or 4140 or similar. The only slightly difficult part is indexing to get the hex.
          Get some M12 & run a tap through them? The cheap ones are probably not hardened.
          Tim
            What Tim said! I do it all the time, beats paying a fortune. I have a bucket full of M12 flange nuts leftover from my shed.
            Will
              yep, m12 is almost the same ..
              gives me another option ...when searching
              not having a lot of luck through especially when googles still doing the returning to page 1 trick
              thanks
              all the best.markj
                This is the only one i can find
                http://www.ebay.co.uk/itm/25-M12-1-7...item1c154d391c
                I've phoned up three UK companies ..the only ones that have them ..one wants £36 when i order 24 of them ..they are unc
                another with...12mm ones want £1.20 each plus vat plus postage..that would turn them into £2 each
                how is it that, these milling clamping kits are made in china/Taiwan ..
                yet no one sells any spare bits and pieces for them.
                all the best.markj
                  Try ebay no 150558140857
                  Tim
                    That would be ok if i had a linisher ..i could quickly get rid of the serrations .
                    will think about that one Tim ..thanks
                    all the best.markj
                      Not your neck of the woods, but easy to get here....
                      http://www.mcmaster.com/#hex-flange-nuts/=do91o6
                        and about as expensive
                        all the best.markj
                          It's $13.25 US to ship a small flat rate box from US to UK. It will take about 30 1/2" flange nuts. Here flange nuts cost about $1 each for import and $2.30 for domestic. Shipping cost per nut is in inverse proportion to the number shipped.
                          Maybe someone on this side of the pond will as a compensated favor buy them and ship to you.
                          Flange nuts are easy to make If you have one of those 5C collet block square and hex thingies to hex them on. Or an indexer.
                          http://business.shop.ebay.com/i.html...k&_sacat=12576
                          Maybe put that in the box too.
                          I've made about a jillion flange nuts and T nuts out of mild steel. I machine them, run them up to red heat , and quench them in cold water. Mild steel doesn't harden much but it will get a tough skin with a cold water quench. I don't draw the temper of mild steel at all. I use them as quenched. They hold up pretty well. Case hardened or alloy steel is better of course but that's more money.
                          And no, you don't want the nuts in the upper part of the Mc Master Carr linked above. Note it says "distorted thread". Great for aircraft when you want things to stay put. Not so good on machine tools where you change the set up a dozen times a day. Get the ones towards the bottom third of the linked page where it rerfers to "flange nuts for clamping" and goes on to explain how they are sometimes called collar nuts.
                            all the best.markj
                            What's wrong with using the lathe, face off then bang a tap thru ???
                              all the best.markj
                              Just an easy example of a hardened flange nut. McMaster is always the most expensive. If I didn't have a bunch, I'd amble down to my local screw store...
