I need to get my garden tractor put back together but instead I keep pulling parts off of it to fix
This is the steering box (actually this is from the wrong color tractor but it is almost the same gearbox):
http://www.ihcubcadet.com/IHCCFAQ/SteeringBox.htm
The hole that the side plate mounts to is egg shaped. My plan is to bore it out and insert bronze bearings. I have two bearings that, once pressed in, will leave a gap in the middle of the bore for the grease to flow.
My plan is to put this on a faceplate and use shims and three points to mount it. It rocks a bit so the shims will be necessary. I plan on mounting it with the shaft in place so I can verify using a dial indicator that the shaft is perpendicular to the bed ways. The other alignment isn't as critical. I'm shooting for .001" under for the bore. I can peen over the edge of the bore to trap the bearing in place after assembly.
First question - using a HSS boring tool how bad will this interrupted cut be?
Second question - there is a channel cut from the center (where the grease zirc is) to the outside on one side only (the side with the nut). The side that the plate (that holds the finger) is on has no channel. I'm thinking of using a dremel or a small hacksaw blade to create a small channel for grease and am thinking that it should go the entire length of the bore. Any reason not to do that?
