Lathe speed
  • Lathe speed
    I am building an overhead drive system for my 1930 9" lathe. I thought I read somewhere that the proper speed for the countershaft with the step pullys should be around 300 rpm. I have mine setup with a 2 1/2" motor pully driveing a 12" countershaft pully. The motor is 1725rpm reversable capacitor start single phase and should give about 340rpm by my calculations. As I get a little further along I will have some pictures.
    Skip
    I thought about doing that at one point, as a way of isolating the motor and countershaft vibration from the lathe. I'll be interested to see your pictures.
      Skip
      Actually I didn't really word my thread correctly as I am asking is this speed is correct??? Or what is the correct speed for the countershaft??
      Skip
        I think your looking at this from the wrong direction.
        What is the the lowest and highest speed range you want your lathe to operate at ?
        Use that to determine the pulley size & desired rpm of your ceiling mounted countershaft at the lathe end,
        And then use that to determine the pulley sizes at the Jackshaft/ motor end.
        Machinery's Handbook States that the maximum speed for a flat belt drive to be 6000 fpm, so you need to stay below that, If it were me, I'd shoot for about 1/2 that or less.
        I cut it twice, and it's still too short!
        Scott
          Even more to the point, what is the highest speed the lathe is designed to run at? My 10K with essentially the same bearing technology has a top speed of 1475 rpm.
          Lowest speed with backgear etc. is 60 rpm.
            Don't know if this info will be of use to you...
            I converted my late 1930s 10" Sheldon from horizontal to a home brewed overhead version [sorry, no pics posted yet] and isolated motor from lathe as much as possible. Bronze "shell" bearings.
            Stock was 2.5" to 10" pulley (at the counter shaft), with a 1725 rpm motor this yields 431 rpm of the shaft.
            When the two cone pulleys are taken into account, the speeds became 819 rpm, 431 rpm, 226 rpm [4.75" and 2.5"; 3.5" and 3.5"; 4.75" and 2.5"].
            Once refurbed I took slightly more exact measurements, of what I hope is the "effective" diameter of the initial train pulleys, those are 2.75" and 9.75" [the 10" original is still in use but more accurate measurement gets to 9.75"]
            This means speeds become 924 rpm, 486 rpm, 255 rpm.
            I can't give exact speeds in back gear now...that's part of the plan towards completion for tomorrow
