Guys,
I need some help in how to mount a transfer switch for my new 6500watt generator.
My house breaker box is in the utility room, which has finished walls. The box is flush mounted, in between the studs and flush with the wall surface. There is a small freezer below the box, a cabinet immediatly to the right, a door to the left, and a bunch of wiring coming in from the top and bottom.
The box is mounted to a stud on the left, with only about 6 inches of clear space from the mounting stud to the one immediatly to its left, which is where the door is mounted. On the right hand side of the box is where the ground lug is installed, no room there to bring in the wires.
The transfer switch I am considering getting is a 6 switch unit which has a flex conduit about 2 foot long to connect to the breaker box. It is shown as surface mounted next to the breaker box which is also surface mounted, in the advertizing photos. I can obvisly make the flex conduit any length needed.
I obviously don't have a surface mounted box, and little choice where I can mount my transfer switch. My current thought is to surface mount the transfer switch above the breaker box, and run flex conduit thru a hole in the wall board to connect to one of the few unused holes in the breaker box.
My question is, is running the conduit thru a hole in the wall board legal from the code perspective? I don't think I could mount the transfer switch as a flush mount due to all the wiring going out of the breaker box. If I could "streach" the wires and run them around the switch box I probably could. Would that mean putting a large junction box above the transfer switch to splice on longer wires for the 8 or 9 wires coming down (3 leads each means 27 splices)?
I need some help here!!
