Coolant hose source?
  • Coolant hose source?
    I need some armored coolant hose,3/8"ID,by armored I mean flexible metal jacketed so chips don't melt holes in it.Our big lathe at work has the coolant line ran inside a flexible wire tray.I'm tired of replacing it every few months due to chips melting holes in it.The original hose that came with the machine had a thin spiral sheet metal jacket similar to Greenfield electrical wire.
    Any ideas where to find it?
    Stay-Put Flexible Metal Coolant Hose: http://www.mcmaster.com/#catalog/117/2187/=dummnb
    That said, Loc-Line would also work and is easily found.
      Nice chromed metal clad hoses at your bathroom store!
        Why not buy a few feet of armored wire and just rip the wire out and run some hose of your choice through the center?
          Grohe handshower and pull-out facet hoses... 1/2 inch IP fitting on each end. Dead easy. Oh... they have a lifetime warranty Many other brands also... but I know that Grohe is metal, not chomed plastic.
          Those "stay-put" flex hoses from McMaster look like the ticket though!
            You could have a look around here.
            http://www.summitracing.com
              Guess I should have mentioned I need a 14 foot long piece of it Not the nozzle end either,the supply length that runs from the coolant pump to the carriage.
              Thought about flexible conduit,but it won't bend as tight a radius as the wire tray.Also limited on space in the tray.
                ha.. 3x 5 foot shower hoses! Super flexible...
                or you can order all sorts of metal clad hose from McMaster in lengths up to the full reel (100ft)
                Example - look up the item and it will take you to the catalog page:
                Item 5676T32 - $40 for the first foot with one male and female fitting, 54 cents an inch after that.
                or, for really flexible and 1558 psi...
                Item 54875K13 - $43.54 plus $1.39 per inch.
