cnc plasma table
  • cnc plasma table
    Do any of you all have or use a CNC plasma cutter table? There are quite a few projects coming up that I could use one.
    I would want a table capable of handling at least 2.5m x 1.5m material.
    I`ve got a 3m x 1.5m cnc table.Wish now I had bought a longer bed machine.Would have had more time cutting and less time loading.
      ePlasma table
      Ihave a home built one that works well and will take up to a5X10 ft. sheet. Owning one of these WILL change the way you work!
      Plain ol Bill
        Bill, do you happen to have photos of and plans for your DIY table?
        WI/IL border, USA
          I built one years ago and it was fun to do and fun while it lasted.
          It was small 4x4 or so and used a small inverter plasma machine..
          good up to 3/8.
          they make way too much of a mess for me, though, to have justified
          keeping it. I changed the torch out for a router .. that was a lot more
          fun as you could do some limited 3D stuff in wood/plastic/etc.
          i broke it down and have all the parts with the intention of building
          a smaller router table instead with a good spindle and plenty of Z axis.
          keep in mind that they are loud and they are dirty.. unless you have another
          space to put it in or a heavy shower curtain I'd suggest making something
          beefier that you can use for other tools and drop the plasma in every
          now and again when you need it.
          Tony
            I'm currently building one when I have the spare time.I probably have half the parts made so far.Just have to get the base and water tank done,then it's on to the electronic stuff.
            Oh,the mess is a problem,that's why I'm going with a water tank.No smoke or sparks that way.
              i had a water tank!
              maybe it wasn't deep enough (fills full of crap FAST).. or close enough
              to the table surface, i dunno.
              word of wisdom: make the short axis higher off of the table than you
              think you need. cutting thin sheet makes it warp ALOT and you'll crash
              often (or move your sheet & lose your ref) if your overhead clearance is
              too small.
              Tony
                Originally posted by Tony
                i had a water tank!
                too small.
                Tony
                Point taken,16" deep seems to be the minimum depth on most commercialy built ones.Also I plan on making the cutting grid a unit that lifts out with at least 10" of water under it.
                Going to have 12" of Z travel and the water tank will be capable of being lowered another 6".Planning a 4th axis to handle up to 12" tubes as well.
                  Sort of documented build
                  Michael you asked if I had more info about my build. I did a rough documentation at the time and you can find it here:
                  http://www.cnczone.com/forums/plasma...10_plasma.html
                  It was a fun project!
                  Plain ol Bill
                    Very nice!
                    Nice knives to BTW!
                      Thank you, Bill. Very impressive!
                      WI/IL border, USA
