I wanted to put some screw slots in some 303SS so I made a fixture out of aluminum to hold the pieces even with the top of the fixture. Used a HSS 1.75 in. diameter screw slotting saw .064 in. thick and ran at 120 rpm using a slow feed rate (a little less than 2 in./min.).I tried .010 and .015 DOC and climb milled. Slots came out good, but the aluminum clogged up the teeth of the saw. Were these milling parameters OK? Couldn't find much about using these saws in my books. Any easy way to get the aluminum out of the saw teeth without ruining the saw?
Chris
Chris
