Cleaning the shop floor - what do you use?
  • Cleaning the shop floor - what do you use?
    Just looking to see what's worked for you guys. There used to be a powder that when sprinkled on the floor and watered down would turn green like antifreeze and then you would scrub the floor. It worked great for the mechanic bays. Anyone know what that was? I'm going back 20 years now too. It came in a pale and was made for shop floor cleaning. I guess it's no good anymore with all the environmental issues so what do you use that's effective at removing grease and oils and just bringing back some of the concrete under the mess?
    "To invent you need a good imagination and a pile of junk" Thomas Edison
    Better to have tools you don't need than to need tools you don't have
    73's KB3BFR
    I use E-85.
      Don't know what its called, suspect more than one "name", but I'd go looking where they sell those kits for painting garage floors...IIRC, part of the kit (and available separately) are a series of washes (some acid) for prepping the floor...should help some...
        I know one memeber you won't be getting an answer from! He hasn't seen his shop floor in years!
        I'll give you a hint. POS bridgeport.
          According to my wife, the best thing for cleaning the workshop floor of oil and swarf are my workboots. They manage to get it all off the workshop floor and bring it into the house and onto the carpet.
            A broom works well, followed by a vacuum.
            If I ever decide to try to clean oil etc, one thing is for sure....
            I WILL NOT BE USING E85 !!!!!!!
            Probably I will use some detergent cleaner, or maybe "purple cleaner".... it won't hurt the concrete, it prevents rust, and it does clean up oil.
              The yellow/green powder concrete cleaner that we used in the auto shop where I worked was called "Hound Dog." It worked great.
                I use sawdust to clean up oil. I have a cheap $99 chinese table saw on the far side of the shop I save all the saw dust from it. I sprinkle saw dust on the floor it soaks up the oil and it seems to suck it right out of the cement floor. If I get oil all over my mill or lathe I sprinkle saw dust on them at the end of the day. Next morning the shop vac sucks off all the saw dust and the oil is gone too. It takes 30 seconds to sprinkle saw dust and about 1 minute to suck it up you can't beat that for quick clean up.
                If I run out of saw dust I cut up a few scrap board to make more. About 3 or 4 coffee cups of saw dust is about all I need to clean my mill or lathe.
                  Libellous remarks
                  I had a sweep up last week, cleaned the benches down and vacuum'd up round the Bridgeport.
                  Getting a new 16 year old apprentice on Monday, need to start him off right
                    Greasy or oily floors are cleaned by brushing kerosene on the oily areas and then putting floor dry on overnight. Then sweeping the floor the next day.
                      I use the dog
                      he used to be white but now has a glossy gray/black coat
                      nb; cheaper than sawdust
                      John
                      I used to be indecisive. Now I'm not so sure , but I'm not a complete idiot - some bits are still missing
                        http://www.interstateproducts.com/concrete_cleaners.htm
                          You make me laugh
                          73's KB3BFR
                            Finally !!!!!! You know how many years I've tried to at least put a name to that stuff? Damn right - it did work very good too!!! All we did was work it in with a stiff bristle floor broom. Then simply hosed it off and used a squeegee after that. Now I need to find if it's around still... Thanks!
                            edit: it still is: http://www.americanplus5.com/product952.html
                            73's KB3BFR
                              Use Oil Dry from any automotive store. Put it on the grease /oil let it set over night and then rub with a brick or piece of 2X4 then pick it up. Kinda dusty but works good.
                              Ross
                              GUNS Don't kill people
                              Drivers using cell phones do.
