I want to turn a Morse Taper 6 on my lathe.
The gauge dimension is: 63.348
The taper is: 19.180:1
I will use the compound set over to ???
The chart I found for the dimensions:
Morse Taper dimensions (mm) Morse Taper number Taper A B (max) C (max) D (max) E (max) F G H J K
0 19.212:1 9.045 56.5 59.5 10.5 6 4 1 3 3.9 1° 29' 27"
1 20.047:1 12.065 62 65.5 13.5 8.7 5 1.2 3.5 5.2 1° 25' 43"
2 20.020:1 17.780 75 80 16 13.5 6 1.6 5 6.3 1° 25' 50"
3 19.922:1 23.825 94 99 20 18.5 7 2 5 7.9 1° 26' 16"
4 19.254:1 31.267 117.5 124 24 24.5 8 2.5 6.5 11.9 1° 29' 15"
5 19.002:1 44.399 149.5 156 29 35.7 10 3 6.5 15.9 1° 30' 26"
6 19.180:1 63.348 210 218 40 51 13 4 8 19 1° 29' 36"
7 19.231:1 83.058 285.75 294.1 34.9
