Spark proof tools
  • Spark proof tools
    The other day, I was pondering why most of us get away with working on carburetors, fuel injectors, and fuel systems using steel tools. There is usually some spilled gasoline involved . Refinery workers have non-sparking tools, but apparently very few auto mechanics use them. Even safety conscious companys don't seem to require their auto mechanics to use non-sparking tools, as far as I know. Has that changed as of late ? In general, to ignite gasoline fumes, we need to be within the flamability limits with regard to air/fuel mixture, and have enough heat from a spark to start combustion. I think that much of the time we dance around those requirements , mostly by luck, and seldom if ever start a fire. But then, occasionally, somebody will be cleaning parts with gasoline, create a spark , and go up in flames.
    Its all a factor of quanity... of fumes.
    First off, cleaning parts in gasoline? Hardly very smart. Kerosene is nearly as effective and MUCH safer.
    Second, in a shop, you can stop what your doing and evacuate an area if you spill a large amount of gasoline, and hence a large amount of fumes are created. You can smell gasoline long before it reachs its flamable mixture point.
    In a refinery... Fumes are everywhere, You can't shut anything down if you spill something, Beancounters would'nt allow it.
    Even if you did spill some gasoline in a shop and ignite it, you'd likey have low fumes (No explosion) and ability to put it out, with minimal risk of it spreading to the fuel tank, and no pressurised fuel lines to worry about. And the tanks are never pressurised so no explosion risk even if they did 'catch fire', Just a slowly building flamethrower as more and more gasoline boils off.
    IMO, its safer for the shops to work in a fume free enviorment and use sparking tools, then it would be to try and work in a spark free enviorment and ignore fumes/fuel leaks.
    Plus, I would like you to point me to the non sparking welder and the non sparking muffler cutoff saw first
    How about the non sparking bolt cutter? (Are there non sparking alloys strong enough?)
    How about the non sparking spark plug tester?
    Or the fact that cars are definately not 'non sparking' when the battery is connected/disconnected and any loaded switch opening/closing would likey generate a small spark in a car
      I always understood that it was because of confined spaces & potentially explosive atmospheres.
      It's easier to say "use these tools" rather than "use these tools here and here, but you don't need to use them here"
      Given enough time, I'm sure OSHA will get around to it, whether it's justified or not, it's for our own good.
      I cut it twice, and it's still too short!
      Scott
        Personally, I've never been in an auto shop that wasn't well ventilated. Most have the doors up all the time. Even when I worked in a Pontiac shop way back in 69-70 in Northern Ohio there was plenty of ventilation. And there were fire extinguishers about ever 10-12 feet. At least one per work stall. That was back when guys would be working on cars with a cigarette hanging out of their mouth. I can't remember any fire incidents. Of course, that was also back when most folks had common sense and lawsuits were as rare as hen's teeth.
        By the way, I was at work and we could hear the gun fire coming from Kent State University several miles away. That was the day of the riot when the Ohio National Guard fired on the students. Didn't find out about what the "explosions" were until I got home that night. Tragic day in our history.
          LOL... I just happened to recall that gasoline fires weren't on the minds of most of us. There were far more dangerous things around the shop. Balancing the rear tires always scared the crap out of me. It took two people. The rear tires would be jacked-up about three inches off the floor. One person on the balancer ring spinning four inches from your face and another behind the steering wheel holding the throttle at 60mph in drive.
            I think you'll find most refineries don't use 'spark proof tools' anymore. They don't last and studies showed that they will spark. The place I worked at hadn't used them since the sixties.
              I used to work in printing. The ink rooms and wash rooms required spark proof tools and LEL monitors for all work.
                Probably the reason you get away with it is because most carbs are aluminum or zinc based alloys.
                Even with steel tools it will be hard to get a spark.
                Although I can't use them the chlorinated water based solvents are used more now.
                Guaranteed not to rust, bust, collect dust, bend, chip, crack or peel
                  The non-sparking tools that I am familiar with are made from berillyum bronze. Working with explosives, particularly in ammo storage, and these were mandatory. They had a few drawbacks:- 1) they cost A LOT, 2) they could not take the same abuse as "normal" tools, 3) they were heavy!
                  Basically they were a royal pain to use, and some verged on the ridiculous. Think about a berillyum bronze cold chisel or even a claw hammer, and a 4-foot Stillson-pattern pipe wrench weighed a ton! Of course, forged aluminum wrenches had yet to be "discovered!"
                  And before ANYONE cautions us about the toxicity hazard of berillyum, it is primarily from the dust, and you wont generate much using a non-sparking file!
                  Duffy, Gatineau, Quebec
                    I remember when I was about 9 years old I discovered, much to my profound disappointment, that lit matches dropped into a cup of gasoline simply go out.
                    The lack of burning auto repair shops would seem to suggest that gasoline isn't quite as easy to ignite as some would think.
                      Last time I checked none sparking plyers were $450 compaired to $5 steel plyers.
                      I brass barrel bung wrench is about $500 compaired to $15 steel wrench.
                      I don't think the brass makes the tools expensive the low sales quantity makes them expensive.
                        Interesting.
                        I used to make ink mixing machines, only small ones like a food mixer on steroids.
                        The company these were for Coates Lorelliux later Sun Chemicals had some big hydraulic mixers that could mix 1 tonne at a time.
                        Only hydraulic to get the torque needed to move the paddle thru what was basically tar before the temp got up as it mixed.
                        All the other mixers were just 3 phase standard motors.
                        I didn't recall any emphasis being put on sparks or fire other than standard risks
                          During the course of my career as a firefighter for 29 years in a Department that is the 7th largest in the nation (240,000+ calls/year when I retired) I never responded to a vehicle fire caused by sparking tools. There were many vehicle fires with other causes; electrical shorts and welding/cutting operations being the most prevalent. As was stated by KIMFAB, the materials used in most vehicle manufacture aren't prone to sparking. Not that it can't be done, but try to get a spark by striking a piece of mild steel with a wrench or even something harder like a chisel. Although not impossible it isn't something that readily occurs therefore it is unlikely that simply dropping a tool would induce a spark.
                          The exception to that being someone who drops a tool across an electrical connection causing a short. Then all bets are off, but it wouldn't matter what non sparking material the tool was made of unless it was non conductive as well. Given the advances in plastics and composites one day there may be tools made with those properties that are strong enough to withstand working forces, wear well and can be produced cost effectively.
                          There is also the issue of air/fuel ratio. Most automotive fuels have a relatively narrow flammability range in comparison to gases like acetylene. That range is rarely attained under most shop circumstances.
                          Temperatures also play an important role. For example, many people treat diesel as if it were pretty safe. It is rated as a combustible liquid, not flammable (as is kerosene). In fact a lit fusee can be inserted into liquid diesel under the right conditions without causing ignition. The rating is dependent on Flash Point based on temperature. Even so, a diesel fuel spill on pavement in Florida during a hot summer day must be treated as a flammable liquid spill. It will flash as easily as gasoline will under less severe conditions due to increased temperatures.
                            Remember how difficult it is to flambee ? We do it over here with christmas pudding. You absolutely have to heat the brandy before pouring it on the hot pudding and plate, or it is very hard to light.
                            Same with petrol/gas. At room temperature it won't do much. Maybe in the heat in the southern states it might, but even then you'll only get a naked flame that you can put out with a blanket.
                            I worked in the mining industry when portable computing equipment was coming along, in the 70's and 80's. Inspectorate were very nervous of new equipment being taken underground. It was several years before they trusted the kit not to develop induced voltages high enough to ignite escaped methane. And that was when, as soon as you knew there was an escape of gas, you should be legging it out anyway.
                            But it wasn't the damage of an explosion that was the problem, but the fact that after the explosion, and any subsequent burning, the availability of breathable oxygen was reduced. You could work with gas filters on your belt, but you couldn't work with a tank on your back all day long.
                            Richard - SW London, UK, EU.
                              Similar experience w/auto gas tank quite full of gas
                              DISCLAIMER: CAUTION, DO NOT TRY THIS AT HOME!
                              Just out of high school in 1965 I was stuffing a 413 cu. in. Chrysler engine into a rusted out 1957 T-Bird.
                              Following drag racing practice at the time I was re-locating the biggest truck battery I could find to the trunk.
                              Too lazy to drag out an electric drill & extension cord & my oxy/acet cutting torch was right there, sooooo I punched a quick hole in the floor of the trunk for the hold down bolts.
                              Looking through the hole, I saw what looked like more of the POS undercoating they used back then (which is why the car was so rusty) and used the torch to punch another hole through the 'undercoating'.
                              BIG flame shot up, and I think I filled my pants as I was jumping out of the trunk expecting the car to explode.
                              Watched for an instant as the flame went out by itself w/o no intervention from anything.
                              I am NOT recommending this to anyone, I am just adding a personal experience to second the statements that several factors have to be in place for a fire/explosion to occur.
                              Allow me to repeat:
                              Best wishes to ya’ll.
                              Sincerely,
                              Jim
