Toy: Compaq iPaq 3835
  • Toy: Compaq iPaq 3835
    One of these followed me home... it was included in a box of other more useful computer gew-gaws.
    Near as I can tell it works. It's just old and the internal battery is shot... I think.
    It has the jacket with a secondary battery... I plug it in the red light on the back flashes... what does that mean?
    When I take it off the charger the device shuts down. Looking at the "power" screen I see:
    MAIN:
    0 -- 100%
    That tells me nothing. If the battery was 100% the device wouldn't shut down when I take it off the charger.
    Will the device run with the external battery and just that? I've got it on the charger... going to let it sit overnight before I do anything.
    Can the internal battery be revived? I see I can get a replacement... but I'd prefer not to spend money on a historical curiosity if I can avoid it.
    More or less I want to use it for the "you damn kids and your fancy iCrap you have no idea" factor.
    "The Administration does not support blowing up planets." --- Finally some SENSIBLE policy from the Gov!
    Once a lithium ion is dead it's all over with. They must be replaced. Trying to force charge a Lithium will cause it to burst with flames.
    Check ebay for a battery, probably pretty cheap.
      Found one for $10.
      I wish to avoid the flames.
