Help, size of replacement motor
  • gary hart
    Yes, like the lazy and easy way. Didn't know one was available at reasonable price. Paul T.. thanks for letting me know.
  • PaulT
    If you want to take the lazy approach and keep the original motor, you can buy VFD's that take 110 volt single phase input and generate 3 phase 220 volt output.
    I think the max motor size for these special VFD's is 2 HP.
    You can see them at www.dealerselectric.com .
    Paul T.
    www.power-t.com
  • gary hart
    Thanks for answer...... gary
  • lakeside53
    On 60hz, it's a 900watt (1.2hp) 1800 rpm type that develops full hp when loaded to 1670rpm.
    A 1725rpm 1.5hp will work fine.
  • gary hart
    started a topic Help, size of replacement motor
    Helping someone to change his hydraulic pump motor from 3 phase to single phase and wanting to use 115 VAC if possible.
    I don't understand this motor rating. Would a standard 1725 rpm motor of 1-1/2 hp rating with capacitor start work for a replacement?
    A VFD with 115 VAC input doesn't seem to be an option for a 1-1/2 hp motor.
