Oversized tool holders - What to do?
  • Oversized tool holders - What to do?
    I picked up some oversized tool holders that are too wide to fit in my South Bend lantern tool post. I also have a bunch of cutters that fit them, so I'd like to be able to use them if it's reasonable.
    Had a couple of ideas of how to best deal with them.
    - Mill them down on the sides so they're narrow enough to fit into the tool post.
    - Fabricate a wider lantern style post.
    - Sell them and just buy some smaller ones.
    One is a knurling tool and one's a boring bar holder, so they'll definitely be useful.
    Thoughts?
    Yeah, Id just "adjust" them. As long as they aren't so large to get in the way. The extra bulk even after milling off the offending metal could be a plus.. JR
      they are likely to be very hard
        As stated the metal will be hard and you will need to grind them to size or use a carbide in the mill.
        I would go with machining a larger tool holder to fit your lathe.
          Hmmm... hadn't thought about that. Perhaps fabbing up a larger tool post would be the way to go. I have some spare tool post parts that I could use as a starting point... got the washer and bottom plate, so I'd just need the post itself.
            Have you checked that the tool holders come in equal to or under the lathe spindle centre height.
            Phil
              Trade them. Has to be someone with a larger lathe and too few tool holders.
                Weld a bit of square bar onto the side.
                "...do you not think you have enough machines?"
                  I had the exact same issue. Whole box of #1 toolholders, but needed more #0 for my 9A and shaper.
                  Listed them on PM, sold a few, traded the rest. Now I have a full set of all available #0 toolholders, plus some extras for the shaper.
                  But..... The best answer is still an AXA QCTP.
                    I have a few tool holders that have been milled down so they cant be that hard.
                      Good excuse to build a tool post and holders.
                        Get rid of the lantern and get a QCTP.
                          Dont be a girl's blouse, grab your angle grinder and make those holders fit.
                            not knowing any better, i milled some armstrong #2s that were beat up pretty bad to fit a 13" leblond. i think the only endmills i had at the time were carbide resharps from e-bay. easy job for my rong-fu mill.
                              Rex is right, put that crap on e bay or the junk pile and get a tool post.
