1/2" bronze plate got sawed up today.
  • 1/2" bronze plate got sawed up today.
    Using the Milwaukee metal cutting saw I bought used from Ebay,and a new blade,we got the 4' x 8' x 1/2" bronze plate cut into 6 pieces that are 1' x 4'. I left 1 piece 2' x 4' in case a larger piece is needed.
    Chris Vesper,the toolmaker from Australia,has been staying here all week,and was a very big help,as my knee has gone bad this last month.
    The smaller pieces weigh about 100#,and are manageable to get them up onto the Roll In bandsaw.
    This is something I have wanted to get done for a long time.
    Well done! sorry bout the knee, hope the swarf didnt sting too much!
    mark
      What, no pictures of the awsome cut it left? or all the swaff?
        What are you making with it?
          This is a Milwaukee 6370, correct?
          How did it perform relative to the directions in the manual regarding cycle
          times for material thicknesses beyond 1/4" ?
          From pg.10 of the Owner's Manual
          The following are duty cycles to be followed by subsequent
          cool down intervals of 60 minutes switched off (or 6 minutes
          of no-load operation).
          Cap ..... Max Dur ... Max Leng ... Feed Rate (Sec / Inch)
          3/8" ... 30 - 40 sec ... 15" ...... 2 - 3
          1/2" ... 18 - 36 sec .... 9" ....... 2 - 4
          5/8" ... 18 - 30 sec .... 6" ....... 3 - 5
          3/4" ... 20 - 25 sec .... 5" ....... 4 - 5
          Earlier discussions: Metal Cutting Circular Saws & How to cut 1/2" thick Naval brass
            It took about 5 minutes of total actual cutting time to make each 4' cut. We let the saw cool down and made knurls while waiting for the saw to cool.
            I am not doing anything with the bronze yet,as I am pretty out of it with my knee. Just wanted to get it into manageable size pieces so it COULD be used later on.
            The saw performed fine. I had bought a new 42 tooth blade for it. The blade still seems fine after the cutting.
              That is a bit more aggressive than the rate suggested in the manual for 1/2".
              Sounds like the saw performed well and withstood the heat buildup, nonetheless.
              Thanks for the follow-up. Here is hoping that you enjoy better mobility and
              comfort soon.
                Those saws are surprisingly good. Our firm has two guys use two of them to dismantle a large steel chimnea recently. Our fellow went to make a demonstration and when he got this small hand-held circular saw out of the boot of his car he got a lot of mocking and derisory remarks from the assembly - until he ran it along a 15mm thick plate with little effort.
                Monarch 10EE 1942
