The Turbo Encabulator.
  • The Turbo Encabulator.
    Sounds like a lot of the replies here ... haaha!
    http://www.indresinc.com/Assets/MANU...01-EMD.pdf.pdf
    And the original .....
    http://www.youtube.com/watch?v=Ac7G7...eature=related
    No translation needed here. right?
    I make messes.
    A classic. The technobabble flows like water!
    "The Administration does not support blowing up planets." --- Finally some SENSIBLE policy from the Gov!
      I think I had him as an instructor in one of my classes
        Anybody need one? I've still got one and it's still in it's original factory box.
        No good deed goes unpunished.
          do you have the original shipping fixture to hold the girdle spring in pandermic alignment ?
            No, but it's easily diagnosed with a meter. It shows up as a standard head code, caught easily by just about anyone.
            Nyuk Nyuk ...
            I make messes.
              They neglected to mention adjustment of the hantoon rantoon, the spanish flutes, and the dual chromed gofaster.
              I make messes.
                Turboencabulator
                No need to waste time on that stuff - any decent mechanic would already know the basics!
                  But quite necessary if you want that "A.S.S.H.E.A.D Certified" patch on your shirt.
                  I make messes.
                    That has been on here many time. The original is actually a paper from the 40's and has been redone many times.
                    http://en.wikipedia.org/wiki/Turboencabulator
                    Another one:
                    IBM Mouse Balls...
                    "Memo of the Month," From The Washington Monthly, January/February 1991, page 24:
                    This is an actual alert to IBM Field Engineers that went out to all IBM Branch Offices. The person who wrote it was very serious. The rest of us find it rather funny.
                    Abstract: Mouse Balls Available as FRU (Field Replacement Unit)
                    Mouse balls are now available as FRU. Therefore, if a mouse fails to operate or should it perform erratically, it may need a ball replacement. Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel.
                    Before proceeding, determine the type of mouse balls by examining the underside of the mouse. Domestic balls will be larger and harder than foreign balls. Ball removal procedures differ depending upon manufacturer of the mouse. Foreign balls can be replaced using the pop-off method. Domestic balls are replaced using the twist-off method. Mouse balls are not usually static sensitive. However, excessive handling can result in sudden discharge. Upon completion of ball replacement, the mouse may be used immediately.
                    It is recommended that each replacer have a pair of spare balls for maintaining optimum customer satisfaction, and that any customer missing his balls should suspect local personnel of removing these necessary items.
                    To re-order, specify one of the following:
                    P/N 33F8462 - Domestic Mouse Balls
                    P/N 33F8461 - Foreign Mouse Balls
