Photo: Krupp Works 1923
Tags: None
I guess it isn't just a matter of "Hey, Joe, give me a hand stacking and organizing this stuff"...
BTW, you just gave away your source.Free software for calculating bolt circles and similar: Click Here
The lathe looks bass-ackwards doesn't it; like maybe they flipped the negative.
Look at the tool posts on the two carriages. There seems to be one on each side of the machine. 4 tools? One on each side? heavier cuts possible without deflection the part?Makes sense if you increase productivity.
I could make guesses til the cows come home as to the purpose of all thise forgings in the foreground but it would be pure speculation. Krupp was probably the largest and most competitive heavy industry manufacturer.
Anyone ever read "The Arms of Krupp" by William Manchester? It's a good look at the evolution of the Industrial Revolution as well as one of the foundations of the Third Reich. Manchester is an excellent biographer. He makes the story unfold before your eyes.
Well, it's Krupp, so it's likely (though by no means certain) they're gun barrels. Artillery or tank gun tubes, maybe?
Looks to me like a single forging or casting that's machined in a mirror-image, then probably sawed in half. Maybe. Interesting the four tool posts and the central roller/support between 'em.
Doc.Doc's Machine. (Probably not what you expect.)
My garage shop has 10 1/2 foot ceiling. On the "list" for this year is a track and chain fall, but no bridge crane. Hmmm... a little bridge crane wouldn't be out of the question....Free software for calculating bolt circles and similar: Click Here
I've always wanted to build a two bay shop with a bridge crane and a pit in one bay. In the pit I'de have a trolley on rails with a transmission jack mounted on it. Then I could pull transmissions or differentials, roll them out of under the vehicle, and hook on to them with the bridge crane to take them to the bench. That bridge crane would be great for moving those heavy machine tools into and around the shop. Many small railroads had just such a shop with the bays in the front and the machine shop in the back with the bridge crane extending over the entire shop so that components could be taken to and from the machine shop directly to the work bays.
In the mid 60's I met a gentleman in Kent, Ohio who had a two car garage with a tall ceiling and an "I" beam with a chainfall. It ran the whole lenght of the center of the first bay and he had bent it into a nice gentle radius so that it went from that bay over the long work bench along the back wall of the other bay. Quite handy I thought!
Regards, Ken
