I bought a new Dewalt rotary laser a couple of years ago, haven't used it much, but what I've done with it has worked well. I laid out and dug the drain field for my septic system using it and I have built a few porches with it. The drain field project worked out well because I was able the set the level to the correct fall for the drain lines, from that point it was just dig and measure
hope this helps
