For need of a regulator with return ports.
  • For need of a regulator with return ports.
    There is a fuel pressure regulator in there, lets get it out.
    I used fittings that I can use nitrous jets in. This way I can just change them out if I need to adjust the jetting or they can be pulled out quickly for inspection of debris and cleaning.
      Nice to be able to do that kind of thing. I once built a fuel pressure regulator to use in my Astro van when I couldn't afford the replacement cost. It worked fine, but it was slow responding- the diaphragm assembly had too much mass.
        Yes! I love having ability!
