Compac Indicator Question
  • Compac Indicator Question
    I just got my first Compac test indicator ( 215GA) on eBay and I have a question. Is the stylus angle fixed or is there a slip-clutch like on my Mitutoyo indicator? I gently tried to change the angle by pushing the stylus against the stop, but it does not move under moderate pressure. Please advise.
    RWO
    yes it will move . All of that type indicator ,any brand the tip can be rotated about 120 degrees.
