Atlas 6x18,Sears 101-21400 Lathe
  • Atlas 6x18,Sears 101-21400 Lathe
    I just picked one of these up & the more I learn about the more I like it. I have a 13x40 Import gap Bed, Gear Head lathe but this little on really has class. I also live by Kalamazoo & found that many parts are still available at Clausing in Goshen In. only 50 miles south. Does anyone else have one of these? I also have an Atlas wood lathe/grill press from before 1920 & one of thier last tools a small metal cutting horiz/vertical band saw. New tools are great, but like airplanes I like the old stuff.
    country, in easy stages."
    ~ James Madison
    i have the craftsman version of the 6x18 and use it quite a bit. i also have a rockwell 14x40. i like the craftsman for small,fine work because i can get close to the spinning chuck with a magnifying glass and not worry too much about getting my shirt ripped off. i went thru mine and replaced a bunch of parts and it works great if you dont overload it. i once saw a pic on the net of 6 of these lathes on a large table,3 to a side,back to back, with 6 women operators. rough stock started at lathe #1 and when it came off lathe #6 it was a part for a Norden bomb sight in WW2.
      I also have a little 6x18 (Atlas, I believe, and relabeled by Sears?). It came complete with all the gears and attachments. I added a little Aloris wedge toolpost (smaller than the AXA) and a Bison 3-jaw chuck, and I use it for small stuff only. Got it dialed in last week so that it cuts straight (virtually no taper) in nearly a foot, and it cuts beautifully. Part of the trick was to leave the tailstock gibb a little loose to move it around and snug it up when the tailstock is approximately where you want to use it. Ditto for tightening the tailstock quill clamp.
        My first lathe was the little Craftsman 109. Cute little machine that just wanted to work, but it was just too damn small and I eventually lost patience.
        I ended up trading up to an Atlas 101. I was a little reluctant to get another "mini" lathe after the 109, but she was dirt cheap, so I figured it was worth a shot. What a huge improvement... the 109 was a toy that looked like a lathe. The 101 is an actual lathe writ small.
        I've since traded for a South Bend 9 which I'm finding to be wonderful, but if you're tight on space, the 101 is a pretty nice little machine as long as you understand its limitations and respect its size.
