Don't know if the flux would be an issue, but this stuff has been around for awhile and can be a lifesaver at times..
Soldering copper to aluminum
It's plain metal alloy, no flux at all.Free software for calculating bolt circles and similar: Click Here
I have a roll of Aluminum solder at work. I think it has some silver in the alloy and the flux is quite aggressive.
It works very well for electrical/electronic work, but its mechanical strength isn't that good.
I mostly use it for making connections to PT100 temperature sensors. The wires on these seem to be Nickle plated Iron and can be very reluctant to wet with conventional solder. Once wetted with the Aluminium solder, I wipe them off and use the ordinary stuff.
