I-Beam Prices
  • I-Beam Prices
    My thread seems to have disappeared.
    Can someone tell me a good place to look for prices for I beams?
    Thanks,
    Bob,
    I guess someone figured your post was too much like an advertisement. :-(
    Would a good way to find the lower limit for the price to calculate the weight per foot and determine the scrap value? Anything less than that would be a mistake.
    When I was looking for I beam I found some at my local scrap metal dealer. I imagine they would be a good place for pricing.
      I just priced up three pieces today, 203x203mm at 9m long - £1450 plus VAT delivered. That's over £1000/ton with the delivery!
      Local place in London - so it won't help you I'm afraid.
      Monarch 10EE 1942
        Call a steel dealer. BTW I beams are designated by the weight per foot, so you don't need to calculate it. Width of flange by lbs/ft.
          and be sure that what you actually want is an "I" beam and not a wide flange beam (WFB)
          Joe B
            My son just bought a new beam for his garage ceiling,
            It,s 5 1/2 in flange x 3/4 thick x6inch web x 1/2 inch thick x 40 feet long, think it was $1900.00.
              Just bought some 6x 12.5lb/ft I-beams last week.
              $.65/lb x 12.5lb/ft x 20'=$162.50ea delivered.
                I found a chart online that did not have my beams in it. I am trying to determine the weight per foot.
                6 inch flange X 10 inch high X 3/8 inch web X flange of 1/4 inch at the edge.
                Wierdscience, were your beams new or used?
                Thanks guys for the responses so far.
                  Heres the link to all the different beams and specs you can think of........
                  Last I checked they were selling I beam for .25c a lb at the scrap yard......pretty cheap actually......
                  http://www.structural-drafting-net-e...teel-beam.html
                  Opportunity knocks once, temptation leans on the doorbell.....
                    Check out the lists linked for your sizes. http://www.saginawpipe.com/steel_i_beams.htm
                    Note that in Wide Flange or "W" beams the flange is parallel on all sides.
                    On "I" beams ( actually called "S" or "Standard" beams} the flanges are taperd on the inside. This is what they use for crane rails on most of the jib cranes. Also looks like to "C" channels back to back.
                    New "W" beams run about .50-.60 per lb in the 1000-5000 lb qty. "S" beams will run about .15-.20 per lb more per lb. The smallest and largest sizes tend to run 5-10% higher than the rest of the size range. THese prices are for full lengths usually in 5' increments on the "W" and 20' increments on the "S" beams.
                    Market prices vary a little so shop around.
                      New,The only thing close is a W10 x22
                      http://www.colemetals.com/Ibeams.htm
                      You may have a special section which won't be listed in the charts.In which case you can bust it down by thickness.
                      Steel plate 1" weighs 40.8lbs/sq ft,- 1/2" is 20.4 and so on.
